Garmin Nuvi 2589LMT Display Assembly Replacement
  1. Garmin Nuvi 2589LMT Display Assembly Replacement, Back Panel Assembly: step 1, image 1 of 1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
    Ask FixBot
  2. Garmin Nuvi 2589LMT Display Assembly Replacement: step 2, image 1 of 2 Garmin Nuvi 2589LMT Display Assembly Replacement: step 2, image 2 of 2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
    Ask FixBot
  3. Garmin Nuvi 2589LMT Display Assembly Replacement, Display Assembly: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Using the tweezers, gently pull the ribbon wiring near where it connects to the motherboard to disconnect the ribbon wiring and the display screen from the motherboard.
    • Remove the screen from the device.
    Ask FixBot
Adam Ferraro
947 Reputation
8 Guides authored
USF Tampa, Team 1-2, Nance Fall 2016 Member of USF Tampa, Team 1-2, Nance Fall 2016
USFT-NANCE-F16S1G2
4 Members
8 Guides authored
2 Guide Comments
Could you please advise where can I find replacement screen for this device
joyarvind - Reply Share
I got the ribbon off. There is a plastic piece that flops around that the ribbon was adhered to. Will the replacement ribbon have some type of adhesive on it for installation? Thanks.
Marty Griffin - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 21
All Time: 2,888
