Garmin Nuvi 2589LMT Battery Replacement
  1. Garmin Nuvi 2589LMT Battery Replacement, Back Panel Assembly: step 1, image 1 of 1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Battery Replacement: step 2, image 1 of 2 Garmin Nuvi 2589LMT Battery Replacement: step 2, image 2 of 2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Battery Replacement, Battery: step 3, image 1 of 1
    Tool used on this step:
    $3.99
    Buy
    • Using the angled tweezers, grip the red, black, and green wires connecting the battery to the motherboard, then gently lift away from the motherboard.
  4. Garmin Nuvi 2589LMT Battery Replacement: step 4, image 1 of 1
    • The battery is held in place by adhesive tape on the underside of the battery.
    • Use the opening tools to gently pry underneath the battery and lift upwards to remove the battery.
4 other people completed this guide.
Adam Ferraro
947 Reputation
8 Guides authored
USF Tampa, Team 1-2, Nance Fall 2016 Member of USF Tampa, Team 1-2, Nance Fall 2016
USFT-NANCE-F16S1G2
4 Members
8 Guides authored
3 Guide Comments
Where can I buy this battery
Stan Levin
stan levin - Reply Share
where can I buy this battery
When pulling off the wires, the plug on the motherboard was coming off. How can I fix it again ?
Hans-Joachim Böhnke - Reply Share
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 44
All Time: 5,650
