Garmin Nuvi 2559 Screen Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
50
All Time:
292
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The Garmin Nuvi 2559 (also known simply as Nuvi 2559 LM in some regions) is a portable GPS navigation device used for turn-by-turn navigation. This guide shows you how to replace the touchscreen.
The screen, also called the digitizer + LCD assembly, is responsible for both displaying maps and receiving touch input from the user. Replacing it can restore proper touchscreen responsiveness and clear display if your device has a cracked screen, unresponsive touch, or black display. You can find relevant troubleshooting tips for these symptoms here.
Important tips and warnings:
  • Take care when removing shattered glass; wear gloves to avoid injury.
  • Be aware that adhesive holds the screen in place do not force the screen apart.
  • Disconnect the battery before working with internal components.
  • Use ESD-safe tools to prevent damage to the electronics.
  • Damaged waterproofing may result if the device was previously water-exposed.
  • For guidance on handling broken screens safely, see iFixit Safety Tips.
This guide will walk you step-by-step through safely opening the Garmin Nuvi 2559, removing the old screen, and installing a new one.
Tools
    1. Garmin Nuvi 2559 Screen Replacement, Screen: step 1, image 1 of 2 Garmin Nuvi 2559 Screen Replacement, Screen: step 1, image 2 of 2
      • Flip the device so the backplate is facing upwards.
      Ask FixBot
    2. Garmin Nuvi 2559 Screen Replacement: step 2, image 1 of 2 Garmin Nuvi 2559 Screen Replacement: step 2, image 2 of 2
      • Remove the four 5.0 mm screws from the backplate using a Phillips #1 screwdriver.
      Ask FixBot
    3. Garmin Nuvi 2559 Screen Replacement: step 3, image 1 of 2 Garmin Nuvi 2559 Screen Replacement: step 3, image 2 of 2
      • Insert an opening tool into the seam between the front and back halves of the device.
      • Gently slide the tool along the edges to release the internal clips.
      • Work slowly around the entire perimeter to avoid breaking the plastic tabs.
      • Make sure all screws are fully removed before attempting to open the device.
      Ask FixBot
    4. Garmin Nuvi 2559 Screen Replacement: step 4, image 1 of 3 Garmin Nuvi 2559 Screen Replacement: step 4, image 2 of 3 Garmin Nuvi 2559 Screen Replacement: step 4, image 3 of 3
      • Use an opening tool to gently pry the ribbon cable from its connector.
      • Work slowly around each clip or latch to avoid damaging the internal components.
      • Once the plastic frame is fully released, carefully separate it from the motherboard and set it aside.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 50
All Time: 292
