Introduction
This guide shows how to remove the touch screen on your Garmin Nuvi 2455LMT through the back panel assembly.
Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
Locate the edge of the screen that fits into the plastic case
To separate the connector, gently push the tip of a spudger under the clip.
Then, swing the clip over to the other side of the socket, so that it lays flat against the cable.
