Garmin Nuvi 2455LMT Back Panel Assembly Replacement
  1. Garmin Nuvi 2455LMT Back Panel Assembly Replacement, Back Panel Assembly: step 1, image 1 of 1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
    Ask FixBot
  2. Garmin Nuvi 2455LMT Back Panel Assembly Replacement: step 2, image 1 of 2 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: step 2, image 2 of 2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
    Ask FixBot
  3. Garmin Nuvi 2455LMT Back Panel Assembly Replacement: step 3, image 1 of 3 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: step 3, image 2 of 3 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: step 3, image 3 of 3
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
    Ask FixBot
2 other people completed this guide.
Nathaniel Williams
264 Reputation
2 Guides authored
USF Tampa, Team 2-3, Blackwell Fall 2016 Member of USF Tampa, Team 2-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G3
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 1,305
