Garmin Nuvi 200w Screen Replacement
    1. Garmin Nuvi 200w Screen Replacement, Rear Cover: step 1, image 1 of 3 Garmin Nuvi 200w Screen Replacement, Rear Cover: step 1, image 2 of 3 Garmin Nuvi 200w Screen Replacement, Rear Cover: step 1, image 3 of 3
      • Peel off the sticker in order to find the two Torx T5 screws.
      Ask FixBot
    2. Garmin Nuvi 200w Screen Replacement: step 2, image 1 of 1
      • Remove the two 4mm T5 Torx screws.
      Ask FixBot
    3. Garmin Nuvi 200w Screen Replacement: step 3, image 1 of 3 Garmin Nuvi 200w Screen Replacement: step 3, image 2 of 3 Garmin Nuvi 200w Screen Replacement: step 3, image 3 of 3
      • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
      • Once you have a little gap, work it around the whole device with the tool to get separation.
      • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
      Ask FixBot
    4. Garmin Nuvi 200w Screen Replacement: step 4, image 1 of 2 Garmin Nuvi 200w Screen Replacement: step 4, image 2 of 2
      • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
      Ask FixBot
    1. Garmin Nuvi 200w Screen Replacement, Display Assembly: step 5, image 1 of 3 Garmin Nuvi 200w Screen Replacement, Display Assembly: step 5, image 2 of 3 Garmin Nuvi 200w Screen Replacement, Display Assembly: step 5, image 3 of 3
      • Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
      • Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
      • Slide the orange ribbon cable away from the ZIF connector.
      Ask FixBot
    1. Garmin Nuvi 200w Screen Replacement, Screen: step 6, image 1 of 3 Garmin Nuvi 200w Screen Replacement, Screen: step 6, image 2 of 3 Garmin Nuvi 200w Screen Replacement, Screen: step 6, image 3 of 3
      • Using your plastic opening tool, apply pressure on the top right of the screen in order to remove some of the tabs.
      • Work the plastic opening tool around the whole screen to remove the tabs from the screen.
      • Carefully separate the screen from the front cover.
      Ask FixBot
Matthew Eires
319 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 632
