Garmin Nuvi 200W Rear Cover Replacement
    1. Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: step 1, image 1 of 3 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: step 1, image 2 of 3 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: step 1, image 3 of 3
      • Peel off the sticker in order to find the two Torx T5 screws.
      Ask FixBot
    2. Garmin Nuvi 200W  Rear Cover Replacement: step 2, image 1 of 1
      • Remove the two 4mm T5 Torx screws.
      Ask FixBot
    3. Garmin Nuvi 200W  Rear Cover Replacement: step 3, image 1 of 3 Garmin Nuvi 200W  Rear Cover Replacement: step 3, image 2 of 3 Garmin Nuvi 200W  Rear Cover Replacement: step 3, image 3 of 3
      • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
      • Once you have a little gap, work it around the whole device with the tool to get separation.
      • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
      Ask FixBot
    4. Garmin Nuvi 200W  Rear Cover Replacement: step 4, image 1 of 2 Garmin Nuvi 200W  Rear Cover Replacement: step 4, image 2 of 2
      • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
      Ask FixBot
Matthew Eires
319 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 19
All Time: 541
