Garmin Nuvi 200 Rear Casing Replacement
    1. Garmin Nuvi 200 Rear Casing Replacement, Rear Casing: step 1, image 1 of 2 Garmin Nuvi 200 Rear Casing Replacement, Rear Casing: step 1, image 2 of 2
      • Peel off the sticker from the bottom of the device to reveal two screws.
      Ask FixBot
    2. Garmin Nuvi 200 Rear Casing Replacement: step 2, image 1 of 1
      • Remove two T5 Torx screws.
      Ask FixBot
    3. Garmin Nuvi 200 Rear Casing Replacement: step 3, image 1 of 2 Garmin Nuvi 200 Rear Casing Replacement: step 3, image 2 of 2
      • Insert a plastic opening tool in the gap between the front and rear casing.
      • Carefully work the tool around the gap, separating the two halves of the case.
      • Keep the power switch in place while removing the rear case.
      Ask FixBot
Finish Line
2 other people completed this guide.
Stuart Heater
155 Reputation
1 Guide authored
Cal Poly, Team 25-90, Amido Spring 2010 Member of Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 37
All Time: 5,122
