Garmin Nuvi 200 Display Replacement
Views: 11K
View statistics:
Past 24 Hours:
0
Past 7 Days:
7
Past 30 Days:
47
All Time:
11,478
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Opening the Nuvi and replacing a broken/damaged display.
Tools
    1. Garmin Nuvi 200 Display Replacement, Rear Casing: step 1, image 1 of 2 Garmin Nuvi 200 Display Replacement, Rear Casing: step 1, image 2 of 2
      • Peel off the sticker from the bottom of the device to reveal two screws.
      Ask FixBot
    2. Garmin Nuvi 200 Display Replacement: step 2, image 1 of 1
      • Remove two T5 Torx screws.
      Ask FixBot
    3. Garmin Nuvi 200 Display Replacement: step 3, image 1 of 2 Garmin Nuvi 200 Display Replacement: step 3, image 2 of 2
      • Insert a plastic opening tool in the gap between the front and rear casing.
      • Carefully work the tool around the gap, separating the two halves of the case.
      • Keep the power switch in place while removing the rear case.
      Ask FixBot
    1. Garmin Nuvi 200 Display Replacement, Display: step 4, image 1 of 1
      • Apply pressure to the tabs holding the screen in place with the plastic opening tool
      Ask FixBot
    2. Garmin Nuvi 200 Display Replacement: step 5, image 1 of 2 Garmin Nuvi 200 Display Replacement: step 5, image 2 of 2
      • Apply pressure to the same tabs again to remove the front of the screen.
      Ask FixBot
    3. Garmin Nuvi 200 Display Replacement: step 6, image 1 of 2 Garmin Nuvi 200 Display Replacement: step 6, image 2 of 2
      • Peel away the material holding the ribbon cable in place.
      • Peeling the sticker halfway will allow you to access the ribbon cable. Removing it fully will allow you to detach the upper case from the lower case.
      Ask FixBot
    4. Garmin Nuvi 200 Display Replacement: step 7, image 1 of 2 Garmin Nuvi 200 Display Replacement: step 7, image 2 of 2
      • Disconnect the ribbon cable from the logic board.
      • Make sure to disconnect the cable from both ports.
      Ask FixBot
    5. Garmin Nuvi 200 Display Replacement: step 8, image 1 of 2 Garmin Nuvi 200 Display Replacement: step 8, image 2 of 2
      • The display consists of two screens which are held together by the ribbon.
      Ask FixBot
4 other people completed this guide.
Nick
7 Reputation
1 Guide authored
Cal Poly, Team 25-90, Amido Spring 2010 Member of Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 47
All Time: 11,478
