Garmin Nuvi 200 Battery Replacement
Views: 50K
View statistics:
Past 24 Hours:
2
Past 7 Days:
29
Past 30 Days:
123
All Time:
50,044
Comments: 13
13 guide comments.
Go to guide comments
Completed: 19
19 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replacing the battery in the Garmin Nuvi 200
Parts
Tools
    1. Garmin Nuvi 200 Battery Replacement, Rear Casing: step 1, image 1 of 2 Garmin Nuvi 200 Battery Replacement, Rear Casing: step 1, image 2 of 2
      • Peel off the sticker from the bottom of the device to reveal two screws.
      Ask FixBot
    2. Garmin Nuvi 200 Battery Replacement: step 2, image 1 of 1
      • Remove two T5 Torx screws.
      Ask FixBot
    3. Garmin Nuvi 200 Battery Replacement: step 3, image 1 of 2 Garmin Nuvi 200 Battery Replacement: step 3, image 2 of 2
      • Insert a plastic opening tool in the gap between the front and rear casing.
      • Carefully work the tool around the gap, separating the two halves of the case.
      • Keep the power switch in place while removing the rear case.
      Ask FixBot
    1. Garmin Nuvi 200 Battery Replacement, Logic Board: step 4, image 1 of 1
      • Peel away the tape holding the ribbon cable in place.
      • Disconnect the ribbon cable by using a spudger to flip up the retaining flap on its ZIF-style connector. Then gently remove the cable.
      Ask FixBot
    2. Garmin Nuvi 200 Battery Replacement: step 5, image 1 of 1
      • Pull out the cable between the logic board and the speaker to disconnect them.
      Ask FixBot
    3. Garmin Nuvi 200 Battery Replacement: step 6, image 1 of 2 Garmin Nuvi 200 Battery Replacement: step 6, image 2 of 2
      • Remove the three screws from the logic board using the #00 Phillips screwdriver.
      • Lift the board away from the case but do not pull the logic board completely off, as it is still attached to the battery by a cable.
      Ask FixBot
    4. Garmin Nuvi 200 Battery Replacement: step 7, image 1 of 2 Garmin Nuvi 200 Battery Replacement: step 7, image 2 of 2
      • Detach the logic board form the battery by pulling out the cable.
      Ask FixBot
    1. Garmin Nuvi 200 Battery Replacement, Battery: step 8, image 1 of 2 Garmin Nuvi 200 Battery Replacement, Battery: step 8, image 2 of 2
      • Do not use any sharp objects around the battery, as these may puncture the battery.
      • Remove the battery by pulling it away from the casing.
      • The battery is glued to the casing.
      Ask FixBot
19 other people completed this guide.
Anjelica
579 Reputation
3 Guides authored
Cal Poly, Team 25-90, Amido Spring 2010 Member of Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Members
60 Guides authored
13 Guide Comments
This document could be improved by including information about where to acquire a replacement battery, and any modifications that might be required to a generic battery.
Jonathan Moore - Reply Share
Seems like there are some on Amazon and Ebay. Not sure how to verify getting the right one. Not that expensive, so maybe worth the risk.
Jim Carnicom - Reply Share
It was a huge mistake to peel away the ribbon cable. It needs matched up precisely and exactly in the same alignment as it was before during reassembly, an apparently impossible task once it's been detached. I'd advise opening the halves in book form, leaving the ribbon cable as a hinge. Have about given up trying to position it.
Nice tutorial, except for the booby trap.
gepetto4 - Reply Share
Yep, fell into this trap, too. The Nuvi powers up but no video. Can't place the ribbon cabe just exactly so. Ugh.
webo666.666 - Reply Share
Cannot stress enough that the step 5 calling for the removal of the tape holding the ribbon cable be removed from this guide! My Nuvi will not work anymore because I can't get that ribbon cable aligned. I wish I had read all the comments as the above poster warned of this very problem. Please update the guide and remove step 5!
Jarrod - Reply Share
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 123
All Time: 50,044
