Garmin Nuvi 1490T USB Port Replacement
  1. Garmin Nuvi 1490T USB Port Replacement, Front Frame Panel: step 1, image 1 of 1
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
    Ask FixBot
  2. Garmin Nuvi 1490T USB Port Replacement: step 2, image 1 of 1
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
    Ask FixBot
  3. Garmin Nuvi 1490T USB Port Replacement: step 3, image 1 of 2 Garmin Nuvi 1490T USB Port Replacement: step 3, image 2 of 2
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
    Ask FixBot
  4. Garmin Nuvi 1490T USB Port Replacement, Second Frame Panel: step 4, image 1 of 3 Garmin Nuvi 1490T USB Port Replacement, Second Frame Panel: step 4, image 2 of 3 Garmin Nuvi 1490T USB Port Replacement, Second Frame Panel: step 4, image 3 of 3
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
    Ask FixBot
  5. Garmin Nuvi 1490T USB Port Replacement: step 5, image 1 of 3 Garmin Nuvi 1490T USB Port Replacement: step 5, image 2 of 3 Garmin Nuvi 1490T USB Port Replacement: step 5, image 3 of 3
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
    Ask FixBot
  6. Garmin Nuvi 1490T USB Port Replacement, Display Screen: step 6, image 1 of 3 Garmin Nuvi 1490T USB Port Replacement, Display Screen: step 6, image 2 of 3 Garmin Nuvi 1490T USB Port Replacement, Display Screen: step 6, image 3 of 3
    • Gently lift up the display screen using your fingers to make sure the only thing connecting it to the body is the ribbon cable.
    Ask FixBot
  7. Garmin Nuvi 1490T USB Port Replacement: step 7, image 1 of 2 Garmin Nuvi 1490T USB Port Replacement: step 7, image 2 of 2
    • Remove the piece of tape that is covering the connecting point of the motherboard and display.
    Ask FixBot
  8. Garmin Nuvi 1490T USB Port Replacement: step 8, image 1 of 3 Garmin Nuvi 1490T USB Port Replacement: step 8, image 2 of 3 Garmin Nuvi 1490T USB Port Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Using the plastic opening tool or your fingers, lift up the ZIF connector holding the ribbon cable in place.
    • Carefully pull the ribbon cable out of the connector with tweezers or two fingers.
    • Gently disconnect the display by pulling upward. Set display aside.
    • If the display screen does not disconnect easily, make sure the ZIF connector is no longer holding it in place.
    Ask FixBot
  9. Garmin Nuvi 1490T USB Port Replacement, USB Port: step 9, image 1 of 2 Garmin Nuvi 1490T USB Port Replacement, USB Port: step 9, image 2 of 2
    • Use your T5 Torx screwdriver and unscrew the two 5.0 mm screws on the motherboard.
    Ask FixBot
  10. Garmin Nuvi 1490T USB Port Replacement: step 10, image 1 of 2 Garmin Nuvi 1490T USB Port Replacement: step 10, image 2 of 2
    Buy
    • Flip the motherboard over towards the battery.
    • Use your tweezers and disconnect the two wire connectors from the motherboard.
    • Pull the motherboard out and locate the USB port.
    Ask FixBot
  11. Garmin Nuvi 1490T USB Port Replacement: step 11, image 1 of 2 Garmin Nuvi 1490T USB Port Replacement: step 11, image 2 of 2
    • If this is your first time solder here is a link on how to solder. How To Solder and Desolder Connections
    • Gently and delicately heat up the solder holding the USB port to the circuit board.
    • Carefully remove the USB port with your metal tweezers and set it aside
    Ask FixBot
7 other people completed this guide.
Ricardo Solis
1,058 Reputation
6 Guides authored
USF Tampa, Team 15-2, Remmell Spring 2016 Member of USF Tampa, Team 15-2, Remmell Spring 2016
USFT-REMMELL-S16S15G2
4 Members
10 Guides authored
3 Guide Comments
I found one on ebay, cost about 5 USD.  Search for micro USB jack.
Heliophile - Reply Share
those are not micro usb, there mini usb.
ricky bennett - Reply Share
Did I miss something? The title implies showing how to REPLACE the port. It ends with remove port and set aside, then reverse. On the off-chance the authors are still reading the comments, sarcastic “good job”. I also marvel that it took three of you geniuses to come up with this. I’m gonna follow Heliophile’s advice and search ebay, his or her 2 line comment was way more useful then the entire piece. Thanks Heliophile.
Mark Burrows - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 41
All Time: 5,832
