Garmin Nuvi 1490T Display Screen Replacement
  1. Garmin Nuvi 1490T Display Screen Replacement, Front Frame Panel: step 1, image 1 of 1
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
    Ask FixBot
  2. Garmin Nuvi 1490T Display Screen Replacement: step 2, image 1 of 1
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
    Ask FixBot
  3. Garmin Nuvi 1490T Display Screen Replacement: step 3, image 1 of 2 Garmin Nuvi 1490T Display Screen Replacement: step 3, image 2 of 2
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
    Ask FixBot
  4. Garmin Nuvi 1490T Display Screen Replacement, Second Frame Panel: step 4, image 1 of 3 Garmin Nuvi 1490T Display Screen Replacement, Second Frame Panel: step 4, image 2 of 3 Garmin Nuvi 1490T Display Screen Replacement, Second Frame Panel: step 4, image 3 of 3
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
    Ask FixBot
  5. Garmin Nuvi 1490T Display Screen Replacement: step 5, image 1 of 3 Garmin Nuvi 1490T Display Screen Replacement: step 5, image 2 of 3 Garmin Nuvi 1490T Display Screen Replacement: step 5, image 3 of 3
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
    Ask FixBot
  6. Garmin Nuvi 1490T Display Screen Replacement, Display Screen: step 6, image 1 of 3 Garmin Nuvi 1490T Display Screen Replacement, Display Screen: step 6, image 2 of 3 Garmin Nuvi 1490T Display Screen Replacement, Display Screen: step 6, image 3 of 3
    • Gently lift up the display screen using your fingers to make sure the only thing connecting it to the body is the ribbon cable.
    Ask FixBot
  7. Garmin Nuvi 1490T Display Screen Replacement: step 7, image 1 of 2 Garmin Nuvi 1490T Display Screen Replacement: step 7, image 2 of 2
    • Remove the piece of tape that is covering the connecting point of the motherboard and display.
    Ask FixBot
  8. Garmin Nuvi 1490T Display Screen Replacement: step 8, image 1 of 3 Garmin Nuvi 1490T Display Screen Replacement: step 8, image 2 of 3 Garmin Nuvi 1490T Display Screen Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Using the plastic opening tool or your fingers, lift up the ZIF connector holding the ribbon cable in place.
    • Carefully pull the ribbon cable out of the connector with tweezers or two fingers.
    • Gently disconnect the display by pulling upward. Set display aside.
    • If the display screen does not disconnect easily, make sure the ZIF connector is no longer holding it in place.
    Ask FixBot
5 other people completed this guide.
Ricardo Solis
1,058 Reputation
6 Guides authored
USF Tampa, Team 15-2, Remmell Spring 2016 Member of USF Tampa, Team 15-2, Remmell Spring 2016
USFT-REMMELL-S16S15G2
4 Members
10 Guides authored
1 Guide Comment
Awesome!! Thank you for putting this out there. Helped me save buying a new gps when the screen on my got damaged.
George Gearing - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 30
All Time: 3,113
