Garmin Nuvi 1450 Motherboard Replacement
  1. Garmin Nuvi 1450 Motherboard Replacement, Battery: step 1, image 1 of 2 Garmin Nuvi 1450 Motherboard Replacement, Battery: step 1, image 2 of 2
    • Remove the gray bezel with an opening pick.
    Ask FixBot
  2. Garmin Nuvi 1450 Motherboard Replacement: step 2, image 1 of 3 Garmin Nuvi 1450 Motherboard Replacement: step 2, image 2 of 3 Garmin Nuvi 1450 Motherboard Replacement: step 2, image 3 of 3
    • Remove the four 2.5 mm-long screws with a T4 Torx screwdriver.
    Ask FixBot
  3. Garmin Nuvi 1450 Motherboard Replacement: step 3, image 1 of 1
    • Remove the black bezel with an opening pick.
    Ask FixBot
  4. Garmin Nuvi 1450 Motherboard Replacement: step 4, image 1 of 2 Garmin Nuvi 1450 Motherboard Replacement: step 4, image 2 of 2
    • Caution: The battery itself is double-taped to the assembly, so it will take time and care to remove it without damage.
    • Remove the battery slowly by using an opening tool to pry the underside of the battery, and use another opening tool as leverage to lift the battery slowly. After some time, you should have the battery free from the frame.
    Ask FixBot
  5. Garmin Nuvi 1450 Motherboard Replacement: step 5, image 1 of 3 Garmin Nuvi 1450 Motherboard Replacement: step 5, image 2 of 3 Garmin Nuvi 1450 Motherboard Replacement: step 5, image 3 of 3
    • Remove the tape covering the two 3.25 mm-long screws on the motherboard using your hands or Tweezers.
    • Remove the two 3.2 mm-long screws with a T4 Torx screwdriver.
    Ask FixBot
  6. Garmin Nuvi 1450 Motherboard Replacement: step 6, image 1 of 2 Garmin Nuvi 1450 Motherboard Replacement: step 6, image 2 of 2
    • Disconnect the battery connector.
    • Remove the battery.
    Ask FixBot
  7. Garmin Nuvi 1450 Motherboard Replacement, Motherboard: step 7, image 1 of 2 Garmin Nuvi 1450 Motherboard Replacement, Motherboard: step 7, image 2 of 2
    • Use a Bit Driver and a 2.5mm Flat Bit to remove the speaker wire connecting to the motherboard, and then remove the motherboard you plan to replace.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Christopher Keehn
348 Reputation
3 Guides authored
Texas Tech, Team 45-48, Weston Fall 2025 Member of Texas Tech, Team 45-48, Weston Fall 2025
TTU-WESTON-F25S45G48
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 26
All Time: 138
