Up to 20% off select tools
Garmin GPSmap 60CSx Screen Replacement
Views: 6.1K
View statistics:
Past 24 Hours:
12
Past 7 Days:
35
Past 30 Days:
109
All Time:
6,106
Comments: 2
2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the screen remains blank while the device is turned on, is cracked and unable to be used, or remains unresponsive, the screen may be broken and need to be replaced. The following are steps on how to replace the screen of the Garmin GPSmap 60CSx.
    1. Garmin GPSmap 60CSx Screen Replacement, Back Cover and AA Batteries: step 1, image 1 of 1
      • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
      Ask FixBot
    2. Garmin GPSmap 60CSx Screen Replacement: step 2, image 1 of 1
      • Lift battery release up to remove battery cover.
      Ask FixBot
    3. Garmin GPSmap 60CSx Screen Replacement: step 3, image 1 of 2 Garmin GPSmap 60CSx Screen Replacement: step 3, image 2 of 2
      • Pull AA batteries out.
      Ask FixBot
    1. Garmin GPSmap 60CSx Screen Replacement, Screen: step 4, image 1 of 2 Garmin GPSmap 60CSx Screen Replacement, Screen: step 4, image 2 of 2
      • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
      • Flip the back panel over to view the green electronics board (the PCB) and the PCB cover.
      • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
      Ask FixBot
    2. Garmin GPSmap 60CSx Screen Replacement: step 5, image 1 of 1
      • Take the spudger and place it in the bottom right corner of the black PCB cover.
      • Use the spudger to pry the corner out. This will need to be done to all four corners of the PCB cover.
      • It is best to do remove the bottom corners first.
      • Pull the PCB cover out of the GPSMap 60CSx.
      Ask FixBot
    3. Garmin GPSmap 60CSx Screen Replacement: step 6, image 1 of 2 Garmin GPSmap 60CSx Screen Replacement: step 6, image 2 of 2
      • Carefully use the spudger to lift the PCB a few centimeters.
      • Pull the PCB towards the bottom of the GPSMap 60CSx.
      • This will pull the other components out of the GPSMap 60CSx like the antenna and the screen.
      Ask FixBot
    4. Garmin GPSmap 60CSx Screen Replacement: step 7, image 1 of 3 Garmin GPSmap 60CSx Screen Replacement: step 7, image 2 of 3 Garmin GPSmap 60CSx Screen Replacement: step 7, image 3 of 3
      • Apply light pressure to the four white tabs that are holding the screen in place.
      • The screen will now come off the PCB.
      Ask FixBot
    5. Garmin GPSmap 60CSx Screen Replacement: step 8, image 1 of 1
      • Turn the PCB over so the screen connector is facing you.
      • Move the screen out of the way for access to the screen connector.
      Ask FixBot
    6. Garmin GPSmap 60CSx Screen Replacement: step 9, image 1 of 3 Garmin GPSmap 60CSx Screen Replacement: step 9, image 2 of 3 Garmin GPSmap 60CSx Screen Replacement: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to pull the two white pins on the connector forward.
      Ask FixBot
    7. Garmin GPSmap 60CSx Screen Replacement: step 10, image 1 of 1
      • Remove the screen ribbon connector and screen.
      Ask FixBot
5 other people completed this guide.
Author
with
Thomas Humphrey
549 Reputation
4 Guides authored
2 Guide Comments
i have a 60csx and the battery bounces the liquid, can help me?
salvador2707 - Reply Share
Thank you for these step by step detailed instructions.
jlciscorp - Reply Share
Past 24 Hours: 12
Past 7 Days: 35
Past 30 Days: 109
All Time: 6,106
