Up to 20% off select tools
Garmin GPSmap 60CSx Keypad Buttons Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
100
All Time:
3,637
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
Introduction
Go to step 1 ↓
If the buttons are unresponsive or sticking, the keypad may be compromised and need to be replaced. This is a guide to replace the keypad buttons of the Garmin GPSmap 60CSx.
    1. Garmin GPSmap 60CSx Keypad Buttons Replacement, Back Cover and AA Batteries: step 1, image 1 of 1
      • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
      Ask FixBot
    2. Garmin GPSmap 60CSx Keypad Buttons Replacement: step 2, image 1 of 1
      • Lift battery release up to remove battery cover.
      Ask FixBot
    3. Garmin GPSmap 60CSx Keypad Buttons Replacement: step 3, image 1 of 2 Garmin GPSmap 60CSx Keypad Buttons Replacement: step 3, image 2 of 2
      • Pull AA batteries out.
      Ask FixBot
    1. Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: step 4, image 1 of 2 Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: step 4, image 2 of 2
      • Remove the six 10 mm screws on the back of the device with a Phillips #0 screwdriver.
      • Flip the back panel over to view the green electronics board (the PCB) and the PCB covering.
      • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
      Ask FixBot
    2. Garmin GPSmap 60CSx Keypad Buttons Replacement: step 5, image 1 of 1
      • Place the spudger in the bottom right corner of the black PCB cover and pry the corner out.
      • The previous step will need to be done to the other three corners.
      • It is best to do the two bottom corners first.
      • Pull the black PCB board out of the GPSMap 60 CSx.
      Ask FixBot
    3. Garmin GPSmap 60CSx Keypad Buttons Replacement: step 6, image 1 of 2 Garmin GPSmap 60CSx Keypad Buttons Replacement: step 6, image 2 of 2
      • Carefully use a spudger to lift the PCB a few centimeters.
      • Pull the PCB out towards the bottom of the GPSMap 60CSx.
      • This will pull out all the main components including the antenna and the screen.
      Ask FixBot
    4. Garmin GPSmap 60CSx Keypad Buttons Replacement: step 7, image 1 of 2 Garmin GPSmap 60CSx Keypad Buttons Replacement: step 7, image 2 of 2
      • Take the front panel and apply light force to the buttons.
      • The buttons are part of one unit and should all pop out at once.
      Ask FixBot
3 other people completed this guide.
Author
with
Thomas Humphrey
549 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 100
All Time: 3,637
