Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Garmin Forerunner 620 Battery Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
121
All Time:
3,262
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide shows how to replace the battery of a Garmin Forerunner 620 watch. You will need to unstick the screen, remove the motherboard, and then solder or connect the replacement battery before testing and re-gluing the watch.
    1. Garmin Forerunner 620 Battery Replacement, Battery: step 1, image 1 of 2 Garmin Forerunner 620 Battery Replacement, Battery: step 1, image 2 of 2
      • Detach the screen.
      Ask FixBot
    2. Garmin Forerunner 620 Battery Replacement: step 2, image 1 of 1
      • Unscrew the mainboard (2x Torx)
      Ask FixBot
    3. Garmin Forerunner 620 Battery Replacement: step 3, image 1 of 3 Garmin Forerunner 620 Battery Replacement: step 3, image 2 of 3 Garmin Forerunner 620 Battery Replacement: step 3, image 3 of 3
      • Replace (and re-solder) the battery.
      Ask FixBot
    4. Garmin Forerunner 620 Battery Replacement: step 4, image 1 of 1
      • Replace the screen if necessary.
      Ask FixBot
    5. Garmin Forerunner 620 Battery Replacement: step 5, image 1 of 3 Garmin Forerunner 620 Battery Replacement: step 5, image 2 of 3 Garmin Forerunner 620 Battery Replacement: step 5, image 3 of 3
      • Reassemble and re-glue after testing the device.
      Ask FixBot
To reassemble the device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
phico
295 Reputation
2 Guides authored
2 Guide Comments
Bonjour, quelle est la référence de la colle ?
sciencedesclem - Reply Share
I am replacing the battery in my 620. I seperated the plastic top screen from the lower touch screen, they are joined by UV glue. The photos in this tear down show these as being seperated prior to reassembly. Per the photos there is a contact point between the 2 parts at the bottom of the screen, the guide does not mention the 2 parts being rejoined. Currently GPS cannot get a lock so I wonder if the top plastic screen is the GPS antenna but cannot find anything online on where the antenna is. Any idea on this. Thanks
Paul - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 121
All Time: 3,262
