Up to 20% off select tools
Garmin Forerunner 405 Button Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
92
All Time:
4,384
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 8 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing a button on the Forerunner 405.
    1. Garmin Forerunner 405 Button Replacement, Unscrew backing: step 1, image 1 of 1
      • Unscrew the four 6.35 mm Torx T5 screws securing the backing of the watch.
      Ask FixBot
    2. Garmin Forerunner 405 Button Replacement, Separate Component: step 2, image 1 of 1
      • Pull the backing off the watch.
      Ask FixBot
    3. Garmin Forerunner 405 Button Replacement, Separate: step 3, image 1 of 1
      • Pull the battery wires out from the motherboard slowly.
      Ask FixBot
    4. Garmin Forerunner 405 Button Replacement, Unscrew: step 4, image 1 of 1
      • Unscrew one 4 mm philips screw that attaches the motherboard using a PH000 screwdriver.
      • Lift the motherboard out of the watch.
      Ask FixBot
    5. Garmin Forerunner 405 Button Replacement, Pull apart: step 5, image 1 of 2 Garmin Forerunner 405 Button Replacement, Pull apart: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Push button in and pinch silver clip with tweezers.
      • Pull silver clip off the pin it is on.
      • Pull out button and replace.
      Ask FixBot
Author
with
Kyle Kiwczak
328 Reputation
3 Guides authored
2 Guide Comments
Where to find repair button for FR60? Can it be 3d printed? Garmin asks too much out-of-warranty
vasiljevicic - Reply Share
I took mine apart to find that the jammed button was actually bent. Using two pairs of needle-nose pliers, I was able to straighten it and re-use it. The watch works great now.
keithnbrauneckermil - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 92
All Time: 4,384
