Up to 20% off select tools
Garmin Forerunner 25 Screen Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
96
All Time:
2,355
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
The screen is a vital component to a digital smart watch. With the right tools, replacing the screen can be done efficiently and effectively.
    1. Garmin Forerunner 25 Screen Replacement, Battery: step 1, image 1 of 1
      • Power off your watch before disassembling it.
      • Place the watch on a hard surface with the screen facing down.
      • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
      Ask FixBot
    2. Garmin Forerunner 25 Screen Replacement: step 2, image 1 of 1
      • Pry the old battery out using a plastic spudger.
      Ask FixBot
    1. Garmin Forerunner 25 Screen Replacement, Motherboard: step 3, image 1 of 1
      • Unscrew the two T4 6 mm screws located on both sides of the motherboard.
      Ask FixBot
    2. Garmin Forerunner 25 Screen Replacement: step 4, image 1 of 1
      • Lift the motherboard up using a plastic spudger.
      • Ribbon cables are still attached underneath—be careful when prying the motherboard up.
      Ask FixBot
    3. Garmin Forerunner 25 Screen Replacement: step 5, image 1 of 1
      • Flip the ZIF connectors using a plastic spudger tool.
      • Remove the motherboard.
      Ask FixBot
    1. Garmin Forerunner 25 Screen Replacement, Screen: step 6, image 1 of 1
      • Remove gold piece in the corner using the pointed side of the 4 spudger.
      • Any spudger with a pointed end should work to remove this piece.
      Ask FixBot
    2. Garmin Forerunner 25 Screen Replacement: step 7, image 1 of 1
      • Pry the screen up with a plastic opening tool.
      • Any plastic tool with a flat edge should work to remove the screen.
      • Remove the screen.
      Ask FixBot
Author
with
Suzanne Drumm
85 Reputation
1 Guide authored
IUPUI, Team S5-G3, Baechle Spring 2018 Member of IUPUI, Team S5-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G3
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 96
All Time: 2,355
