Garmin Forerunner 25 Battery Replacement
    1. Garmin Forerunner 25 Battery Replacement, Battery: step 1, image 1 of 1
      • Power off your watch before disassembling it.
      • Place the watch on a hard surface with the screen facing down.
      • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
      Ask FixBot
    2. Garmin Forerunner 25 Battery Replacement: step 2, image 1 of 1
      • Pry the old battery out using a plastic spudger.
      Ask FixBot
Dustin Persohn
235 Reputation
2 Guides authored
IUPUI, Team S5-G3, Baechle Spring 2018 Member of IUPUI, Team S5-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G3
3 Members
36 Guides authored
11 Guide Comments
Thanks for the guide - can you advise what what type/model/of replacement battery is required and whether they are readily available?
cherokeelad - Reply Share
I need to know as well. What kind of battery is it? PD…????
girlie_360 - Reply Share
Just look at the last picture. PD2430C1
Leandro Lind - Reply Share
Well, is that really a photo of a Forerunner25? There is no identification of the watch in the photo. Also, the markings on the battery are faded. Does anyone have more info on this?
Stephen Miller - Reply Share
That’s not the forerunner25. The correct battery for forerunner25 is PD2032C1
Adam Sowalsky - Reply Share
Past 24 Hours: 3
Past 7 Days: 38
Past 30 Days: 111
All Time: 9,046
