Community-Contributed Guide
Introduction
Go to step 1 ↓After months or years of sweat, dust and water your device can become very dirty.
A great problem is non-responsive buttons that can be easily cleaned.
Tools
Remove the strap
Power-off the device
Remove the screws on the front using the Torx T4 screwdriver
Tool used on this step:Tweezers$4.99
Remove the small grey arc on the top of the device with the tweezers
With the tweezers, remove the pin connector linked to the screen
Remove the screen
Remove the 2 screws on the motherboard using the PH #000 screwdriver
Remove the 2 screws holding the sensor between the buttons on the right side of the case
With the tweezers, remove the sensor and detach the case from the motherboard
Remove the seal around the circumference of the watch casing, as you will be handling the casing a lot and you don’t want to risk tearing the gasket.
Using the tweezers, remove the circlips around every button very carefully.
When the circlips are removed, you can pull the buttons off. Do this step carefully because you will also find a return spring inside every button hole
Clean the case, including the hole of the buttons
Clean the buttons and the springs
(OPTIONAL) You can lubrificate the buttons before re-inserting them in the case
Reassemble the watch
11 other people completed this guide.
16 Guide Comments
Thanks for that info. In looking at the pictures, I can’t tell which piece is the battery. Do you think it can be easily replaced? Or is it soldered in? Thanks.
Hi,
the battery is visible in the step 5 and step 6.
It is linked to the mainborad with a connector, It’s not soldered.
It’s glued to the back cover but, in my opinion, it can be easy replaced.
The battery type is "361-00097-00"
The nominal specifications are 255mAh, 0.97Wh and 3.8V
On ebay you can find a new battery: https://www.ebay.it/itm/283519139846?has...
I hope this can help
Maybe do You know where to purchase a gaskets?
Unfortunately, I don’t know where you can find it.
I’ve searched on my favourite websites with no luck.
Question: do I need to disasassemble the screen to change only the battery? Can I just access to it by the rear cover?
Thanks for the info!
