Garmin Fenix 3 Motherboard Replacement
  1. Garmin Fenix 3 Motherboard Replacement, Display Assembly: step 1, image 1 of 2 Garmin Fenix 3 Motherboard Replacement, Display Assembly: step 1, image 2 of 2
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
    Ask FixBot
  2. Garmin Fenix 3 Motherboard Replacement: step 2, image 1 of 1
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
    Ask FixBot
  3. Garmin Fenix 3 Motherboard Replacement: step 3, image 1 of 1
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
    Ask FixBot
  4. Garmin Fenix 3 Motherboard Replacement: step 4, image 1 of 1
    • Set the watch face aside.
    Ask FixBot
  5. Garmin Fenix 3 Motherboard Replacement, GPS Antenna: step 5, image 1 of 1
    • Locate the antenna, which is located on the motherboard.
    Ask FixBot
  6. Garmin Fenix 3 Motherboard Replacement: step 6, image 1 of 1
    • Carefully remove the antenna, and set it aside.
    Ask FixBot
  7. Garmin Fenix 3 Motherboard Replacement, Motherboard: step 7, image 1 of 3 Garmin Fenix 3 Motherboard Replacement, Motherboard: step 7, image 2 of 3 Garmin Fenix 3 Motherboard Replacement, Motherboard: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Locate the two silver 1.4 mm T5 screws, and carefully unscrew them.
    • To avoid losing or dropping the screws once they are loose, use tweezers to extract them.
    Ask FixBot
  8. Garmin Fenix 3 Motherboard Replacement: step 8, image 1 of 2 Garmin Fenix 3 Motherboard Replacement: step 8, image 2 of 2
    • Lift the watch and turn it over one hand. The motherboard should fall out easily.
    • When reinserting your motherboard, slide it in instead of pressing it. The motherboard must go beneath a lip at the base of the watch body.
    Ask FixBot
  9. Garmin Fenix 3 Motherboard Replacement: step 9, image 1 of 1
    • Using the spudger, separate the motherboard from the battery, which are both held together with a mild adhesive.
    Ask FixBot
  10. Garmin Fenix 3 Motherboard Replacement: step 10, image 1 of 1
    • Motherboard without metal cover
    Ask FixBot
6 other people completed this guide.
18 Guide Comments
Hello,
i’m looking for replacement of start/stop button micro switch. Do you know what is the switch number which i can look for?
Thank you
Jan Stefan - Reply Share
that's my problem too and i can't find any solution.
Hamidmonti - Reply Share
How did you remove the metal cover from the moterboard (last picture)
slowrun - Reply Share
Where can I find a replacement Motherboard ? None of my buttons are responding and I can’t even do a Factory reset.
All that works is switching off and back on.
arnaud.lhote - Reply Share
I have exact same issue. I sent my watch to official repair service to Split (Croatia) and they said they aren’t able to fix it. I can see only main screen of the watch, buttons don’t respond at all. Would like to know how to fix the issue.
ilija.veselica - Reply Share
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 82
All Time: 11,564
