Garmin Fenix 2 Watch Straps Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
95
All Time:
4,271
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
You will be removing the existing straps on the watch in order to replace a damaged strap or simply to put a new style of strap on. The tools you will need for this fix is a Torx T9 screwdriver.
Tools
    1. Garmin Fenix 2 Watch Straps Replacement, Watch Straps: step 1, image 1 of 1
      • Grab your Garmin watch and flip it over to get a good view of the four screws that connect the straps to the housing.
      Ask FixBot
    2. Garmin Fenix 2 Watch Straps Replacement: step 2, image 1 of 1
      • Use a Torx T9 screwdriver to remove the four .8mm screws. Once the screws are removed the watch straps should fall out of the housing.
      Ask FixBot
Brandon Barger
1,231 Reputation
5 Guides authored
IUPUI, Team 54-4, Wilson Spring 2016 Member of IUPUI, Team 54-4, Wilson Spring 2016
IUPUI-WILSON-S16S54G4
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 95
All Time: 4,271
