Garmin Fenix 2 Motherboard Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
96
All Time:
5,337
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
We are going to remove the motherboard out of the Garmin Fenix 2 watch. You will need a Torx T9 screwdriver along with a nylon spudger for this fix.
Tools
    1. Garmin Fenix 2 Motherboard Replacement, Battery: step 1, image 1 of 3 Garmin Fenix 2 Motherboard Replacement, Battery: step 1, image 2 of 3 Garmin Fenix 2 Motherboard Replacement, Battery: step 1, image 3 of 3
      • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
      Ask FixBot
    2. Garmin Fenix 2 Motherboard Replacement: step 2, image 1 of 2 Garmin Fenix 2 Motherboard Replacement: step 2, image 2 of 2
      • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
      Ask FixBot
    3. Garmin Fenix 2 Motherboard Replacement: step 3, image 1 of 2 Garmin Fenix 2 Motherboard Replacement: step 3, image 2 of 2
      • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
      • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
      Ask FixBot
    1. Garmin Fenix 2 Motherboard Replacement, Motherboard: step 4, image 1 of 1
      • Use a spudger to pry open the power ribbon from the main board.
      Ask FixBot
    2. Garmin Fenix 2 Motherboard Replacement: step 5, image 1 of 1
      • Use your Torx T9 screwdriver to remove the one .8mm screw that holds the main board to the watch housing.
      Ask FixBot
    3. Garmin Fenix 2 Motherboard Replacement: step 6, image 1 of 1
      • Use the spudger to pry the motherboard out of the housing.
      Ask FixBot
    4. Garmin Fenix 2 Motherboard Replacement: step 7, image 1 of 1
      • Once removed simply separate the digitizer from the main board.
      Ask FixBot
    5. Garmin Fenix 2 Motherboard Replacement: step 8, image 1 of 2 Garmin Fenix 2 Motherboard Replacement: step 8, image 2 of 2
      • Lastly use your spudger tool to pry the data ribbon open from the motherboard. Once the ribbon is removed the board will be free and you can replace the board.
      Ask FixBot
5 other people completed this guide.
Brandon Barger
1,231 Reputation
5 Guides authored
IUPUI, Team 54-4, Wilson Spring 2016 Member of IUPUI, Team 54-4, Wilson Spring 2016
IUPUI-WILSON-S16S54G4
3 Members
60 Guides authored
2 Guide Comments
Ottima, le prime guide che trovo per Garmin Fenix 2. Io metterei una foto con le specifiche della batteria. Saluti.
Ciro Filomeno - Reply Share
Hi there, any idea where I can buy motherboard replacement for my Fenix 1?
hasmanizam - Reply Share
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 96
All Time: 5,337
