Garmin Fenix 2 Housing Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
107
All Time:
5,273
Comments: 7
5 comments on steps, 2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
We will remove all of the components from the watch in order to replace the housing. You will need a nylon spudger and Torx T9 screwdriver.
Tools
    1. Garmin Fenix 2 Housing Replacement, Watch Straps: step 1, image 1 of 1
      • Grab your Garmin watch and flip it over to get a good view of the four screws that connect the straps to the housing.
      Ask FixBot
    2. Garmin Fenix 2 Housing Replacement: step 2, image 1 of 1
      • Use a Torx T9 screwdriver to remove the four .8mm screws. Once the screws are removed the watch straps should fall out of the housing.
      Ask FixBot
    1. Garmin Fenix 2 Housing Replacement, Battery: step 3, image 1 of 3 Garmin Fenix 2 Housing Replacement, Battery: step 3, image 2 of 3 Garmin Fenix 2 Housing Replacement, Battery: step 3, image 3 of 3
      • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
      Ask FixBot
    2. Garmin Fenix 2 Housing Replacement: step 4, image 1 of 2 Garmin Fenix 2 Housing Replacement: step 4, image 2 of 2
      • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
      Ask FixBot
    3. Garmin Fenix 2 Housing Replacement: step 5, image 1 of 2 Garmin Fenix 2 Housing Replacement: step 5, image 2 of 2
      • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
      • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
      Ask FixBot
    1. Garmin Fenix 2 Housing Replacement, Motherboard: step 6, image 1 of 1
      • Use a spudger to pry open the power ribbon from the main board.
      Ask FixBot
    2. Garmin Fenix 2 Housing Replacement: step 7, image 1 of 1
      • Use your Torx T9 screwdriver to remove the one .8mm screw that holds the main board to the watch housing.
      Ask FixBot
    3. Garmin Fenix 2 Housing Replacement: step 8, image 1 of 1
      • Use the spudger to pry the motherboard out of the housing.
      Ask FixBot
    4. Garmin Fenix 2 Housing Replacement: step 9, image 1 of 1
      • Once removed simply separate the digitizer from the main board.
      Ask FixBot
    5. Garmin Fenix 2 Housing Replacement: step 10, image 1 of 2 Garmin Fenix 2 Housing Replacement: step 10, image 2 of 2
      • Lastly use your spudger tool to pry the data ribbon open from the motherboard. Once the ribbon is removed the board will be free and you can replace the board.
      Ask FixBot
    1. Garmin Fenix 2 Housing Replacement, Display: step 11, image 1 of 1
      • The display is also ready to be replaced.
      Ask FixBot
    1. Garmin Fenix 2 Housing Replacement, Housing: step 12, image 1 of 2 Garmin Fenix 2 Housing Replacement, Housing: step 12, image 2 of 2
      • Use a spudger tool to pry the soundboard out of its housing.
      Ask FixBot
    2. Garmin Fenix 2 Housing Replacement: step 13, image 1 of 1
      • Remove the gasket seal from the housing.
      Ask FixBot
    3. Garmin Fenix 2 Housing Replacement: step 14, image 1 of 1
      • Once all your components are removed the housing with buttons is ready to be repaired/ replaced.
      Ask FixBot
5 other people completed this guide.
Brandon Barger
1,231 Reputation
5 Guides authored
IUPUI, Team 54-4, Wilson Spring 2016 Member of IUPUI, Team 54-4, Wilson Spring 2016
IUPUI-WILSON-S16S54G4
3 Members
60 Guides authored
2 Guide Comments
Hi there!
Thanks for the tutorial!
When i reassemble the watch, do i have to put some glue to seal the tiny holes out of the soundboard, or those rubber rings does the job?
I’m just afraid of screwing the waterproof feature of the watch…
Thanks!!
Antenor Heleodoro dos Santos - Reply Share
do you know where i can find atmospheric pressure and temperature sensors?
marco turati - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 107
All Time: 5,273
