Up to 20% off select tools
Garmin Fenix 2 Display Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
6
Past 7 Days:
23
Past 30 Days:
133
All Time:
3,699
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 9 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
We will remove the display from the Garmin watch so it can be replaced. Tools that you will need include nylon spudger and Torx T9 screwdriver.
    1. Garmin Fenix 2 Display Replacement, Battery: step 1, image 1 of 3 Garmin Fenix 2 Display Replacement, Battery: step 1, image 2 of 3 Garmin Fenix 2 Display Replacement, Battery: step 1, image 3 of 3
      • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
      Ask FixBot
    2. Garmin Fenix 2 Display Replacement: step 2, image 1 of 2 Garmin Fenix 2 Display Replacement: step 2, image 2 of 2
      • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
      Ask FixBot
    3. Garmin Fenix 2 Display Replacement: step 3, image 1 of 2 Garmin Fenix 2 Display Replacement: step 3, image 2 of 2
      • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
      • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
      Ask FixBot
    1. Garmin Fenix 2 Display Replacement, Motherboard: step 4, image 1 of 1
      • Use a spudger to pry open the power ribbon from the main board.
      Ask FixBot
    2. Garmin Fenix 2 Display Replacement: step 5, image 1 of 1
      • Use your Torx T9 screwdriver to remove the one .8mm screw that holds the main board to the watch housing.
      Ask FixBot
    3. Garmin Fenix 2 Display Replacement: step 6, image 1 of 1
      • Use the spudger to pry the motherboard out of the housing.
      Ask FixBot
    4. Garmin Fenix 2 Display Replacement: step 7, image 1 of 1
      • Once removed simply separate the digitizer from the main board.
      Ask FixBot
    5. Garmin Fenix 2 Display Replacement: step 8, image 1 of 2 Garmin Fenix 2 Display Replacement: step 8, image 2 of 2
      • Lastly use your spudger tool to pry the data ribbon open from the motherboard. Once the ribbon is removed the board will be free and you can replace the board.
      Ask FixBot
    1. Garmin Fenix 2 Display Replacement, Display: step 9, image 1 of 1
      • The display is also ready to be replaced.
      Ask FixBot
Author
with
Brandon Barger
1,231 Reputation
5 Guides authored
IUPUI, Team 54-4, Wilson Spring 2016 Member of IUPUI, Team 54-4, Wilson Spring 2016
IUPUI-WILSON-S16S54G4
3 Members
60 Guides authored
2 Guide Comments
Do you know where I can buy a new screen?
Grzegorz Strzelecki - Reply Share
θέλω να πάρω καινούρια οθονη. ξέρετε απο που μπορώ να παραγγείλω?
ntinis xatz - Reply Share
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 133
All Time: 3,699
