Introduction
Go to step 1 ↓We will be replacing the battery in the Garmin Fenix 2 watch. You should have a Torx T9 screwdriver on hand and a nylon spudger.
Tools
Spudger4.9
Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
11 other people completed this guide.
7 Guide Comments
can you tell us exactly which battery should be used? Thanks in advance!
Look for: RouteJD Inc PD3032 3.7V 200mAh - I found one on Ebay
Are you certain that's the proper battery? Garmin's website says the Fenix 2 has a 500mAh capacity.
Garmin's website says the battery is a 500mAh capacity. Are you certain that is the correct one?
