Up to 20% off select tools
Garmin Edge 830 USB Port Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
90
All Time:
2,157
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Garmin Edge 830 USB Port  Replacement, Touch Display: step 1, image 1 of 1
      • Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
      • Repeat this process a second to ensure that the glue is becoming loose.
      • Alternative: Use a heat gun or hair dryer to heat up the glue
      Ask FixBot
    2. Garmin Edge 830 USB Port  Replacement: step 2, image 1 of 1
      • Use the Jimmy tool carve around the edges of the screen to break the glue seal.
      Ask FixBot
    3. Garmin Edge 830 USB Port  Replacement: step 3, image 1 of 1
      • Use the iFixit plastic opening tool to pry open the screen.
      Ask FixBot
    1. Garmin Edge 830 USB Port  Replacement, Motherboard: step 4, image 1 of 1
      Tool used on this step:
      $3.99
      Buy
      • Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
      • Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
      Ask FixBot
    2. Garmin Edge 830 USB Port  Replacement: step 5, image 1 of 1
      • Unscrew the three 1 mm screws around the perimeter of the motherboard
      • with the 2nd screw also the light senor will come of the PCB
      Ask FixBot
    3. Garmin Edge 830 USB Port  Replacement: step 6, image 1 of 1
      • Use the reverse tweezers to gently pull on the silver box on top of the motherboard to remove it from the back cover.
      • Alternative: Use a plastic card in between PCB and cover.
      Ask FixBot
    4. Garmin Edge 830 USB Port  Replacement: step 7, image 1 of 2 Garmin Edge 830 USB Port  Replacement: step 7, image 2 of 2
      • Locate the wire connector on the motherboard. Slowly release the wires by gently pulling with the blunt tweezers.
      Ask FixBot
    1. Garmin Edge 830 USB Port  Replacement, Battery: step 8, image 1 of 1
      • Use the halberd spudger to lift and remove the battery from the back cover.
      Ask FixBot
    1. Garmin Edge 830 USB Port  Replacement, USB Port: step 9, image 1 of 1
      • With the T4 screwdriver, unscrew the two 1 mm screws on the green piece located on the inside of the cable connector
      Ask FixBot
    2. Garmin Edge 830 USB Port  Replacement: step 10, image 1 of 1
      • Use the halberd spudger to lift and remove the cable connector from the back cover.
      Ask FixBot
Author
with
Samantha Klopman
293 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 90
All Time: 2,157
