Up to 20% off select tools
Garmin Edge 830 Touch Display
Views: 2.8K
View statistics:
Past 24 Hours:
8
Past 7 Days:
21
Past 30 Days:
101
All Time:
2,752
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
If you find yourself on this guide, it means your screen is frozen, unresponsive or has shut down. In that case, it might be time to replace your screen. With the 3 easy steps listed on this guide, you will have that done in no time! The best part about this step is that you don't need to keep track of any tiny screws. You are simply focusing on softening that glue to remove the screen.
    1. Garmin Edge 830 Touch  Display, Touch Display: step 1, image 1 of 1
      • Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
      • Repeat this process a second to ensure that the glue is becoming loose.
      • Alternative: Use a heat gun or hair dryer to heat up the glue
      Ask FixBot
    2. Garmin Edge 830 Touch  Display: step 2, image 1 of 1
      • Use the Jimmy tool carve around the edges of the screen to break the glue seal.
      Ask FixBot
    3. Garmin Edge 830 Touch  Display: step 3, image 1 of 1
      • Use the iFixit plastic opening tool to pry open the screen.
      Ask FixBot
Author
with
Samantha Klopman
293 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 21
Past 30 Days: 101
All Time: 2,752
