Up to 20% off select tools
Garmin Edge 830 Battery Replacement
Views: 15K
View statistics:
Past 24 Hours:
21
Past 7 Days:
94
Past 30 Days:
412
All Time:
14,588
Comments: 8
4 comments on steps, 4 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
If you find yourself on this guide, it means your battery is draining too quickly. In that case, it might be time to replace your battery. It is important to note that for this step you must remove the touch display and motherboard in order to access the battery. Therefore, the steps for this guide begin with taking off the touch screen followed by the motherboard.
    1. Garmin Edge 830 Battery Replacement, Touch Display: step 1, image 1 of 1
      • Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
      • Repeat this process a second to ensure that the glue is becoming loose.
      • Alternative: Use a heat gun or hair dryer to heat up the glue
      Ask FixBot
    2. Garmin Edge 830 Battery Replacement: step 2, image 1 of 1
      • Use the Jimmy tool carve around the edges of the screen to break the glue seal.
      Ask FixBot
    3. Garmin Edge 830 Battery Replacement: step 3, image 1 of 1
      • Use the iFixit plastic opening tool to pry open the screen.
      Ask FixBot
    1. Garmin Edge 830 Battery Replacement, Motherboard: step 4, image 1 of 1
      Tool used on this step:
      $3.99
      Buy
      • Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
      • Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
      Ask FixBot
    2. Garmin Edge 830 Battery Replacement: step 5, image 1 of 1
      • Unscrew the three 1 mm screws around the perimeter of the motherboard
      • with the 2nd screw also the light senor will come of the PCB
      Ask FixBot
    3. Garmin Edge 830 Battery Replacement: step 6, image 1 of 1
      • Use the reverse tweezers to gently pull on the silver box on top of the motherboard to remove it from the back cover.
      • Alternative: Use a plastic card in between PCB and cover.
      Ask FixBot
    4. Garmin Edge 830 Battery Replacement: step 7, image 1 of 2 Garmin Edge 830 Battery Replacement: step 7, image 2 of 2
      • Locate the wire connector on the motherboard. Slowly release the wires by gently pulling with the blunt tweezers.
      Ask FixBot
    1. Garmin Edge 830 Battery Replacement, Battery: step 8, image 1 of 1
      • Use the halberd spudger to lift and remove the battery from the back cover.
      Ask FixBot
Author
with
Alden Gibbs
265 Reputation
3 Guides authored
4 Guide Comments
I have a Garmin 820. I've seen a video by NewLife2OldStuff on YouTube and they don't heat the seal. But I've tried their method and cant get the opening tool in the groove.
Is the removal of the screen on the 830 the same for the 820? It looks similar.
Gary Roy Hogg - Reply Share
ciao ... puoi indicare le spegifiche giuste della batteria per garmin edge 830?
hi...can you give the correct battery specifications for garmin edge 830?
grazie
giancarlodilorenzo@gmail.com
gianca - Reply Share
I would like to replace the battery and therefore I am looking for a compatible model
I do not recommend trying to change the battery. It's better to buy a case with a prepared battery and change the board and display. There are flat cables coming from the back charger and one of the microphone which are attached to a glue/paste. I destroyed the back charger cable, someone else the microphone cable as they were glued to the battery. There is no way to get any replacement for these cables as of May 2025.
The Jimmy tool and Ifix opener are also not good for opening the display. Better use a X-Acto or Craft knife. The display also easily cracks when trying to lift it out of the case. So keep some kind of weight at the display, especially the corners are sensitive. Cases with battery cost around 25, the display 20.
Ano Nymous - Reply Share
Past 24 Hours: 21
Past 7 Days: 94
Past 30 Days: 412
All Time: 14,588
