Garmin Edge 1000 Motherboard Replacement
  1. Garmin Edge 1000 Motherboard Replacement, Back Cover: step 1, image 1 of 2 Garmin Edge 1000 Motherboard Replacement, Back Cover: step 1, image 2 of 2
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
    Ask FixBot
  2. Garmin Edge 1000 Motherboard Replacement: step 2, image 1 of 2 Garmin Edge 1000 Motherboard Replacement: step 2, image 2 of 2
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
    Ask FixBot
  3. Garmin Edge 1000 Motherboard Replacement, Motherboard: step 3, image 1 of 3 Garmin Edge 1000 Motherboard Replacement, Motherboard: step 3, image 2 of 3 Garmin Edge 1000 Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Remove the three T6 Torx screws to release the motherboard.
    Ask FixBot
  4. Garmin Edge 1000 Motherboard Replacement: step 4, image 1 of 2 Garmin Edge 1000 Motherboard Replacement: step 4, image 2 of 2
    • Disconnect the two bronze tabs connected to the motherboard using an opening tool.
    Ask FixBot
  5. Garmin Edge 1000 Motherboard Replacement: step 5, image 1 of 2 Garmin Edge 1000 Motherboard Replacement: step 5, image 2 of 2
    • Pull the motherboard out from the device.
    Ask FixBot
7 other people completed this guide.
3 Guide Comments
Bonjour
Je cherche la référence du connecteur qui relie l’écran LCD à la carte mère
Il s’agit du connecteur FCP de 50 pins.
Pouvez vous me dire ou je pourrais trouver cette pièce?
En vous remerciant par avance
Stephane Weymeels - Reply Share
How about software?
Leslie Poh - Reply Share
Good job. Any tips where to find a motherboard replacement and it's reference number?
Victor Neto - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 53
All Time: 3,161
