Up to 20% off select tools
Garmin Edge 1000 Back Cover Replacement
Views: 7.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
129
All Time:
7,720
Comments: 3
3 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If there is an issue with your Garmin 1000 Edge (M/N F4ACGQ00) mount, use this guide to replace the back cover of your unit.
The back cover houses the device’s SIM card and battery as well. This guide can be used to gain access to these components as needed.
    1. Garmin Edge 1000 Back Cover Replacement, Back Cover: step 1, image 1 of 2 Garmin Edge 1000 Back Cover Replacement, Back Cover: step 1, image 2 of 2
      • Be sure the device is properly powered all the way off before starting the replacement.
      • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
      • Pull the front side of the device apart from the back side.
      Ask FixBot
    2. Garmin Edge 1000 Back Cover Replacement: step 2, image 1 of 2 Garmin Edge 1000 Back Cover Replacement: step 2, image 2 of 2
      • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
      • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
      Ask FixBot
2 other people completed this guide.
Author
with
Taylor McNees
628 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 129
All Time: 7,720
