Garmin DriveSmart 71 EX Speaker Replacement
    1. Garmin DriveSmart 71 EX Speaker Replacement, Case: step 1, image 1 of 1
      • Unplug and power off the device.
      Ask FixBot
    2. Garmin DriveSmart 71 EX Speaker Replacement: step 2, image 1 of 1
      • Remove the four 5 mm T5 Torx screws securing the rear case.
      Ask FixBot
    3. Garmin DriveSmart 71 EX Speaker Replacement: step 3, image 1 of 3 Garmin DriveSmart 71 EX Speaker Replacement: step 3, image 2 of 3 Garmin DriveSmart 71 EX Speaker Replacement: step 3, image 3 of 3
      • Insert an opening pick into the seam between the front and back cover.
      • Carefully slide the opening pick around the perimeter of the device to release the clips securing the front and rear case.
      • Open the case with care not to strain the display ribbon cable or the microphone cable.
      • You may hear small snapping sounds as the clips release. Don't worry, this is normal.
      Ask FixBot
    1. Garmin DriveSmart 71 EX Speaker Replacement, Speaker: step 4, image 1 of 1
      • Use tweezers to pull the speaker connector directly out of its socket.
      Ask FixBot
    2. Garmin DriveSmart 71 EX Speaker Replacement: step 5, image 1 of 1
      • Lift the speaker out of the device to remove it.
      • If you can't gently remove it with your hands, use a plastic spudger to gently lift the speaker out of its groove.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Julien Bush
219 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 78
