Up to 20% off select tools
Garmin DriveSmart 71 EX Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
76
All Time:
338
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide shows how to remove the back cover of the Garmin DriveSmart 71 EX in order to access the internal components of the device. Removing the back cover may be necessary when replacing parts such as the battery, screen, speaker, charging port, or other internal components. Before beginning, make sure the device is powered off and disconnected from any charger or vehicle power cable. Work on a clean, well-lit surface and keep track of each screw as it is removed, since screws may vary in size or length. Use the correct Torx screwdriver bit to avoid stripping the screws, and use ESD-safe plastic tools when prying near the battery or motherboard. Avoid using metal prying tools whenever possible, as they can damage delicate components or puncture the battery.
    1. Garmin DriveSmart 71 EX Screen Replacement, Case: step 1, image 1 of 1
      • Unplug and power off the device.
      Ask FixBot
    2. Garmin DriveSmart 71 EX Screen Replacement: step 2, image 1 of 1
      • Remove the four 5 mm T5 Torx screws securing the rear case.
      Ask FixBot
    3. Garmin DriveSmart 71 EX Screen Replacement: step 3, image 1 of 3 Garmin DriveSmart 71 EX Screen Replacement: step 3, image 2 of 3 Garmin DriveSmart 71 EX Screen Replacement: step 3, image 3 of 3
      • Insert an opening pick into the seam between the front and back cover.
      • Carefully slide the opening pick around the perimeter of the device to release the clips securing the front and rear case.
      • Open the case with care not to strain the display ribbon cable or the microphone cable.
      • You may hear small snapping sounds as the clips release. Don't worry, this is normal.
      Ask FixBot
    1. Garmin DriveSmart 71 EX Screen Replacement, Screen: step 4, image 1 of 3 Garmin DriveSmart 71 EX Screen Replacement, Screen: step 4, image 2 of 3 Garmin DriveSmart 71 EX Screen Replacement, Screen: step 4, image 3 of 3
      • Carefully flip up the locking tab on the connector to release the display ribbon cable.
      • Gently slide the ribbon cable out out of its socket.
      Ask FixBot
    2. Garmin DriveSmart 71 EX Screen Replacement: step 5, image 1 of 3 Garmin DriveSmart 71 EX Screen Replacement: step 5, image 2 of 3 Garmin DriveSmart 71 EX Screen Replacement: step 5, image 3 of 3
      • Align the replacement screen with the device frame.
      • Reconnect the display ribbon cable securely and resecure the locking flap.
      • Press the screen into place.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Julien Bush
219 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 76
All Time: 338
