Up to 20% off select tools
Garmin DriveSmart 71 EX Case Disassembly
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
66
All Time:
222
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide as a prerequisite to open your Garmin DriveSmart 71EX.
    1. Garmin DriveSmart 71 EX Case Disassembly, Case: step 1, image 1 of 1
      • Unplug and power off the device.
      Ask FixBot
    2. Garmin DriveSmart 71 EX Case Disassembly: step 2, image 1 of 1
      • Remove the four 5 mm T5 Torx screws securing the rear case.
      Ask FixBot
    3. Garmin DriveSmart 71 EX Case Disassembly: step 3, image 1 of 3 Garmin DriveSmart 71 EX Case Disassembly: step 3, image 2 of 3 Garmin DriveSmart 71 EX Case Disassembly: step 3, image 3 of 3
      • Insert an opening pick into the seam between the front and back cover.
      • Carefully slide the opening pick around the perimeter of the device to release the clips securing the front and rear case.
      • Open the case with care not to strain the display ribbon cable or the microphone cable.
      • You may hear small snapping sounds as the clips release. Don't worry, this is normal.
      Ask FixBot
Connor Bassolino
27,066 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 66
All Time: 222
