Introduction
Go to step 1 ↓In this guide, we’ll walk you through the steps to replace the LCD screen on your Garmin DriveSmart 60 LMT. Over time, the display may become cracked, unresponsive, or show distorted images due to impact, water damage, or internal failure. Replacing the LCD screen can restore the device’s full functionality and visibility, saving you the cost of buying a new unit. Before you begin, make sure you have all the necessary tools and replacement parts on hand. You’ll need precision screwdrivers, plastic prying tools, tweezers, and a new compatible LCD assembly. It’s also a good idea to wear an anti-static wrist strap to prevent damage to the device’s internal components.Take care not to use metal tools near the screen or circuit board to avoid scratching or shorting components. If your device has been exposed to moisture or the display shows no image at all.
Tools
Spudger4.9
Use a T4 Torx screwdriver to remove the four 6.3 mm-long screws that secure the rear case.
Using a plastic spudger, gently disconnect the black and red wires (ZIF connector) from the socket on the screen assembly. Take care not to pull on the wires or damage the connector.
To reassemble your Garmin DriveSmart 60 LMT, simply follow the steps in reverse order. Make sure all connections are secure and components are properly aligned before powering on your device.
