Introduction
Go to step 1 ↓Over time, the internal battery in your Garmin DriveSmart 60 LMT can lose its ability to hold a charge, leading to shorter run times or requiring constant connection to a power source. Replacing the battery can restore the device’s portability and reliability. In this guide, you’ll learn how to safely remove the old battery and install a new one. Before you begin, make sure you have a clean, well-lit workspace and the necessary tools, such as a plastic spudger, small screwdriver set, and replacement battery. Use care when handling internal connectors and cables to avoid damage during the process.
Tools
Spudger4.9
Use a T4 Torx screwdriver to remove the four 6.3 mm-long screws that secure the rear case.
Using a plastic spudger, gently disconnect the black and red wires (ZIF connector) from the socket on the screen assembly. Take care not to pull on the wires or damage the connector.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
