Garmin DriveSmart 55 EX Speaker Replacement
  1. Garmin DriveSmart 55 EX Speaker Replacement, Speaker: step 1, image 1 of 3 Garmin DriveSmart 55 EX Speaker Replacement, Speaker: step 1, image 2 of 3 Garmin DriveSmart 55 EX Speaker Replacement, Speaker: step 1, image 3 of 3
    • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
    • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
    • Use opening picks along the perimeter to keep them separated until you can remove the screen.
    Ask FixBot
  2. Garmin DriveSmart 55 EX Speaker Replacement: step 2, image 1 of 3 Garmin DriveSmart 55 EX Speaker Replacement: step 2, image 2 of 3 Garmin DriveSmart 55 EX Speaker Replacement: step 2, image 3 of 3
    • Gently separate the screen from the case and place the device flat on the surface.
    • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
    • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
    • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
    • Gently pry the motherboard up using the plastic opening tool.
    Ask FixBot
  3. Garmin DriveSmart 55 EX Speaker Replacement: step 3, image 1 of 2 Garmin DriveSmart 55 EX Speaker Replacement: step 3, image 2 of 2
    • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
    • Avoid pulling on the cables.
    Ask FixBot
  4. Garmin DriveSmart 55 EX Speaker Replacement: step 4, image 1 of 3 Garmin DriveSmart 55 EX Speaker Replacement: step 4, image 2 of 3 Garmin DriveSmart 55 EX Speaker Replacement: step 4, image 3 of 3
    • Desolder the two solder points with a soldering iron to disconnect the speaker wire from the motherboard.
    • If possible, perform soldering away from the battery.
    • Be careful when using the soldering iron, the tip is hot to the touch and can damage the battery, motherboard, and other surfaces when held or placed on them.
    • Using the plastic opening tool, pry around the speaker to remove it.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 96
