Garmin DriveSmart 55 EX Battery Replacement
    1. Garmin DriveSmart 55 EX Battery Replacement, Battery: step 1, image 1 of 3 Garmin DriveSmart 55 EX Battery Replacement, Battery: step 1, image 2 of 3 Garmin DriveSmart 55 EX Battery Replacement, Battery: step 1, image 3 of 3
      • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
      • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
      • Use opening picks along the perimeter to keep them separated until you can remove the screen.
      Ask FixBot
    2. Garmin DriveSmart 55 EX Battery Replacement: step 2, image 1 of 3 Garmin DriveSmart 55 EX Battery Replacement: step 2, image 2 of 3 Garmin DriveSmart 55 EX Battery Replacement: step 2, image 3 of 3
      • Gently separate the screen from the case and place the device flat on the surface.
      • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
      • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
      • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
      • Gently pry the motherboard up using the plastic opening tool.
      Ask FixBot
    3. Garmin DriveSmart 55 EX Battery Replacement: step 3, image 1 of 3 Garmin DriveSmart 55 EX Battery Replacement: step 3, image 2 of 3 Garmin DriveSmart 55 EX Battery Replacement: step 3, image 3 of 3
      • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
      • Avoid pulling on the cables.
      • Gently remove the battery from the casing.
      • If you're unable to get a grip on it, use the opening tool to lift it enough to get your fingers underneath.
      • Avoid bending or puncturing the battery as it can catch fire.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 36
All Time: 220
