Garmin DriveSmart 50 LMTHD Motherboard Replacement
  1. Garmin DriveSmart 50 LMTHD Motherboard Replacement, Display: step 1, image 1 of 1
    • Remove the four 5 mm screws from the back of the device using a T4 Torx screwdriver.
    Ask FixBot
  2. Garmin DriveSmart 50 LMTHD Motherboard Replacement: step 2, image 1 of 2 Garmin DriveSmart 50 LMTHD Motherboard Replacement: step 2, image 2 of 2
    • Use a spudger to gently pry the locks around the screen, applying even pressure along the edges.
    Ask FixBot
  3. Garmin DriveSmart 50 LMTHD Motherboard Replacement: step 3, image 1 of 2 Garmin DriveSmart 50 LMTHD Motherboard Replacement: step 3, image 2 of 2
    • Carefully open the casing to avoid damaging any fragile components, and gently disconnect the black and red wire plug attached to it.
    • Since the plug is on a hook, unlock it with the spudger tool.
    Ask FixBot
  4. Garmin DriveSmart 50 LMTHD Motherboard Replacement: step 4, image 1 of 2 Garmin DriveSmart 50 LMTHD Motherboard Replacement: step 4, image 2 of 2
    • Flip the Garmin over to the other side in the previous step, and slide the screen backwards to undo the orange connector.
    • Use the pointed end of the spudger tool to lift the clasps and detach the orange connector.
    Ask FixBot
  5. Garmin DriveSmart 50 LMTHD Motherboard Replacement: step 5, image 1 of 1
    • Gently lift the screen case from the back mount.
    Ask FixBot
  6. Garmin DriveSmart 50 LMTHD Motherboard Replacement, Motherboard: step 6, image 1 of 2 Garmin DriveSmart 50 LMTHD Motherboard Replacement, Motherboard: step 6, image 2 of 2
    • Remove the four 5 mm screws from the motherboard using a T4 Torx screwdriver.
    • Detach the two connectors that are connected to the battery and speaker.
    • Gently remove the motherboard.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 21
All Time: 130
