Garmin DriveSmart 50 LMT Battery Replacement
  1. Garmin DriveSmart 50 LMT Battery Replacement, Battery: step 1, image 1 of 1
    • Use a T5 Torx screwdriver to remove the four screws from the bottom case.
    Ask FixBot
  2. Garmin DriveSmart 50 LMT Battery Replacement: step 2, image 1 of 2 Garmin DriveSmart 50 LMT Battery Replacement: step 2, image 2 of 2
    • Insert an opening tool into the seam between the top and bottom case.
    • Slide it around the perimeter of the device to release the clips holding them together.
    • Separate the top and bottom of your GPS.
    • Flip the device so that the motherboard and the battery are facing up.
    Ask FixBot
  3. Garmin DriveSmart 50 LMT Battery Replacement: step 3, image 1 of 1
    • Use the angled tweezers to unplug the battery connector from the motherboard.
    Ask FixBot
  4. Garmin DriveSmart 50 LMT Battery Replacement: step 4, image 1 of 1
    • Use an opening tool or spudger to gently pry the battery out, being careful not to puncture or bend it.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Lydia Barrett
463 Reputation
3 Guides authored
Texas Tech, Team 41-5, Allen Fall 2025 Member of Texas Tech, Team 41-5, Allen Fall 2025
TTU-ALLEN-F25S41G5
3 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 35
All Time: 203
