Tools
Introduction
Go to step 1 ↓If your Garmin Drive 61 LM device is freezing or refusing to power on, utilize this guide to help replace the screen to get back to navigating.
Should the device suddenly freeze or refuse to power on, a symptom of these technical issues may lie with a malfunctioning screen that needs to be replaced.
Before utilizing this device guide, ensure the technical difficulties your Garmin Drive 61 LM is facing aligns with the symptoms for a faulty screen on the troubleshooting page: Garmin Drive 61 LM Freezing
Before beginning to replace the screen, ensure you have all of the correct tools and replacement parts. you will need a T5 screwdriver and a pry tool for taking apart the device. Replacement parts for the screen include a 6.1-inch color touchscreen (LCD + digitizer). If you have a 6.1-inch color touchscreen with dual orientation instead, that is sufficient enough.
Place the device screen side down with the back screws facing up towards the ceiling.
Remove the four T5 Torx screws on the rear case.
Disconnect the screen ribbon cable.
Use an opening tool to gently separate the screen from frame.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
