Garmin Drive 61 LM Battery Replacement
    1. Garmin Drive 61 LM Battery Replacement, Battery: step 1, image 1 of 2 Garmin Drive 61 LM Battery Replacement, Battery: step 1, image 2 of 2
      • Place the device screen side down with the back screws facing up towards the ceiling.
      • Remove the four T5 Torx screws on the rear case.
      Ask FixBot
    2. Garmin Drive 61 LM Battery Replacement: step 2, image 1 of 3 Garmin Drive 61 LM Battery Replacement: step 2, image 2 of 3 Garmin Drive 61 LM Battery Replacement: step 2, image 3 of 3
      • Insert an opening tool into the seam between the rear case and screen.
      • Pry around the perimeter.
      • Pull the rear case and screen apart, with care not to strain the attached ribbon cable.
      • Set the screen next to the rear case.
      Ask FixBot
    3. Garmin Drive 61 LM Battery Replacement: step 3, image 1 of 3 Garmin Drive 61 LM Battery Replacement: step 3, image 2 of 3 Garmin Drive 61 LM Battery Replacement: step 3, image 3 of 3
      • Use a T5 Torx screwdriver to remove the five screws securing the motherboard.
      Ask FixBot
    4. Garmin Drive 61 LM Battery Replacement: step 4, image 1 of 3 Garmin Drive 61 LM Battery Replacement: step 4, image 2 of 3 Garmin Drive 61 LM Battery Replacement: step 4, image 3 of 3
      • Be gentle when removing as these are more delicate parts of your device.
      • Use an opening tool to dislodge the speaker and battery.
      Ask FixBot
    5. Garmin Drive 61 LM Battery Replacement: step 5, image 1 of 2 Garmin Drive 61 LM Battery Replacement: step 5, image 2 of 2
      • Flip the motherboard upside down and use your fingernails to disconnect the battery connector.
      Ask FixBot
    6. Garmin Drive 61 LM Battery Replacement: step 6, image 1 of 1
      • Stick the new battery and speaker back onto the plastic.
      • Reconnect the speaker and battery.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Dhyani Shah
267 Reputation
2 Guides authored
Texas Tech, Team 45-2, Weston Fall 2025 Member of Texas Tech, Team 45-2, Weston Fall 2025
TTU-WESTON-F25S45G2
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 60
All Time: 349
