Garmin Drive 60LM Speaker Replacement
    1. Garmin Drive 60LM Speaker Replacement, Speaker: step 1, image 1 of 2 Garmin Drive 60LM Speaker Replacement, Speaker: step 1, image 2 of 2
      • Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of he device.
      Ask FixBot
    2. Garmin Drive 60LM Speaker Replacement: step 2, image 1 of 3 Garmin Drive 60LM Speaker Replacement: step 2, image 2 of 3 Garmin Drive 60LM Speaker Replacement: step 2, image 3 of 3
      • Remove the back panel using the metal spudger tool.
      • You will not be able to remove the back panel entirely. Make sure to separate the back panel slowly so that you do not rip the orange ribbon inside.
      • The metal spudger tool can cause damage to internal components.
      • Flip the device over with the screen facing upward and open the device.
      Ask FixBot
    3. Garmin Drive 60LM Speaker Replacement: step 3, image 1 of 3 Garmin Drive 60LM Speaker Replacement: step 3, image 2 of 3 Garmin Drive 60LM Speaker Replacement: step 3, image 3 of 3
      • Use a plastic spudger tool to lift the wires from behind the motherboard.
      • Carefully disconnect the wires attaching the speaker to the motherboard using your fingers.
      Ask FixBot
    4. Garmin Drive 60LM Speaker Replacement: step 4, image 1 of 2 Garmin Drive 60LM Speaker Replacement: step 4, image 2 of 2
      • Using a plastic spudger and your fingers, remove the speaker from the device.
      Ask FixBot
Andy Flores
247 Reputation
2 Guides authored
Baylor, Team 3-3, Whitney Spring 2017 Member of Baylor, Team 3-3, Whitney Spring 2017
BU-WHITNEY-S17S3G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 39
All Time: 887
