Up to 20% off select tools
Garmin Drive 60LM Screen Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
110
All Time:
1,525
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Parts
Tools
Introduction
Go to step 1 ↓
To replace the screen in your device you will need a T4 Torx screwdriver, a metal spudger, a plastic spudger, and a replacement screen. Be sure to have a large workspace to avoid mishandling or damaging the device components.
    1. Garmin Drive 60LM Screen Replacement, Screen: step 1, image 1 of 2 Garmin Drive 60LM Screen Replacement, Screen: step 1, image 2 of 2
      • Use a T4 Torx screwdriver to remove the four 6.35mm screws that secure the rear case of the device.
      Ask FixBot
    2. Garmin Drive 60LM Screen Replacement: step 2, image 1 of 2 Garmin Drive 60LM Screen Replacement: step 2, image 2 of 2
      • Remove the back panel using the metal spudger tool.
      • The metal spudger tool can cause damage to internal components.
      • Flip the device over with the screen facing upward and open the device.
      Ask FixBot
    3. Garmin Drive 60LM Screen Replacement: step 3, image 1 of 3 Garmin Drive 60LM Screen Replacement: step 3, image 2 of 3 Garmin Drive 60LM Screen Replacement: step 3, image 3 of 3
      • Use a plastic spudger to flip up the white clamp holding the orange ribbon in place to the motherboard.
      • Lift the screen and orange ribbon away from the motherboard.
      • The metal spudger pictured is not ESD safe. Use a plastic spudger instead.
      Ask FixBot
    4. Garmin Drive 60LM Screen Replacement: step 4, image 1 of 2 Garmin Drive 60LM Screen Replacement: step 4, image 2 of 2
      • Carefully unsnap the plastic border surrounding the screen.
      Ask FixBot
Author
with
yuanhao zu
121 Reputation
1 Guide authored
Baylor, Team 3-3, Whitney Spring 2017 Member of Baylor, Team 3-3, Whitney Spring 2017
BU-WHITNEY-S17S3G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 110
All Time: 1,525
