Garmin Drive 53 EX Motherboard Replacement
    1. Garmin Drive 53 EX Motherboard Replacement, Display: step 1, image 1 of 2 Garmin Drive 53 EX Motherboard Replacement, Display: step 1, image 2 of 2
      • Power off the Garmin Drive 53 EX completely to prevent electrical shorts during the repair.
      • Use a T2 Torx screwdriver to remove all four screws.
      Ask FixBot
    2. Garmin Drive 53 EX Motherboard Replacement: step 2, image 1 of 1
      • Insert a plastic opening tool or a thin prying pick into the seam where the front bezel meets the rear housing.
      • Gently lift the rear casing away from the front assembly, being careful not to strain the internal ribbon cable connecting the screen to the motherboard.
      Ask FixBot
    3. Garmin Drive 53 EX Motherboard Replacement: step 3, image 1 of 1
      • Open the ZIF (Zero Insertion Force) connector on the motherboard by flipping up the small locking tab and sliding the screen’s ribbon cable out.
      • Remove the screen.
      Ask FixBot
    1. Garmin Drive 53 EX Motherboard Replacement, Motherboard: step 4, image 1 of 1
      • Remove the four screws from the motherboard.
      Ask FixBot
    2. Garmin Drive 53 EX Motherboard Replacement: step 5, image 1 of 1
      • Carefully unplug the wires connecting the motherboard and the battery.
      • Remove the motherboard from the GPS.
      Ask FixBot
Prabhav Kuruva
553 Reputation
4 Guides authored
Texas Tech, Team 16-3, Samson Spring 2026 Member of Texas Tech, Team 16-3, Samson Spring 2026
TTU-SAMSON-S26S16G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 77
