Garmin Drive 52 and Traffic Battery Replacement
  1. Garmin Drive 52 and Traffic Battery Replacement, Battery: step 1, image 1 of 3 Garmin Drive 52 and Traffic Battery Replacement, Battery: step 1, image 2 of 3 Garmin Drive 52 and Traffic Battery Replacement, Battery: step 1, image 3 of 3
    • Use a T5 Torx screwdriver to remove the four screws in the corners of the backside of the device.
    • If necessary, use a Jimmy or other pry tool to open the backside of the device.
    Ask FixBot
  2. Garmin Drive 52 and Traffic Battery Replacement: step 2, image 1 of 3 Garmin Drive 52 and Traffic Battery Replacement: step 2, image 2 of 3 Garmin Drive 52 and Traffic Battery Replacement: step 2, image 3 of 3
    • Once the back side is open, flip the ZIF connector's lock bar up.
    • Gently remove the connector.
    Ask FixBot
  3. Garmin Drive 52 and Traffic Battery Replacement: step 3, image 1 of 3 Garmin Drive 52 and Traffic Battery Replacement: step 3, image 2 of 3 Garmin Drive 52 and Traffic Battery Replacement: step 3, image 3 of 3
    • Use a T5 Torx screwdriver to unscrew the four screws securing the motherboard.
    • Gently detach the wiring from the motherboard and left the motherboard out.
    • Use a nylon spudger to gently lift the battery out.
    • Avoid using metal tools near batteries; puncturing or excessively warping batteries can be dangerous.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
Jason Wilson
388 Reputation
4 Guides authored
UMass Dartmouth, Team 1-2, Petersen Fall 2022 Member of UMass Dartmouth, Team 1-2, Petersen Fall 2022
UMASSD-PETERSEN-F22S1G2
6 Members
4 Guides authored
1 Guide Comment
Guide is great. Step by step.
At the end you could probably forgo taking out the motherboard, but better safe than sorry. Only hard part was re-attaching the screen to the zip connector again. Small space, used a flat spidger to flip the zip connector down once I had the connector strip in place.
Thank you for this guide saved me $140 on a GPS.
Chris Massey - Reply Share
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 81
All Time: 2,201
