Garmin Dezl 770LMT Screen Replacement
  1. Garmin Dezl 770LMT Screen Replacement, Back Panel Removal: step 1, image 1 of 2 Garmin Dezl 770LMT Screen Replacement, Back Panel Removal: step 1, image 2 of 2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
    Ask FixBot
  2. Garmin Dezl 770LMT Screen Replacement: step 2, image 1 of 1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
    Ask FixBot
  3. Garmin Dezl 770LMT Screen Replacement: step 3, image 1 of 1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
    Ask FixBot
  4. Garmin Dezl 770LMT Screen Replacement, Screen: step 4, image 1 of 2 Garmin Dezl 770LMT Screen Replacement, Screen: step 4, image 2 of 2
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • After you've removed the back cover, you will see a copper colored ribbon connected to a grey hinge.
    • Carefully remove the hinge from the cord using a spudger and the ribbon will come out.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
    • Make sure to wear an anti-static wrist strap when handling the motherboard.
    Ask FixBot
  5. Garmin Dezl 770LMT Screen Replacement: step 5, image 1 of 3 Garmin Dezl 770LMT Screen Replacement: step 5, image 2 of 3 Garmin Dezl 770LMT Screen Replacement: step 5, image 3 of 3
    • Now you have the screen, which is enclosed by another cover. Remove the eight screws that hold it in place.
    Ask FixBot
  6. Garmin Dezl 770LMT Screen Replacement: step 6, image 1 of 1
    • Once the screws have been taken out, use a spudger to carefully remove the cover. With this cover removed, the screen is now completely exposed.
    Ask FixBot
3 other people completed this guide.
Aleem Waris
146 Reputation
1 Guide authored
USF Tampa, Team 1-3, Lacy Fall 2016 Member of USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 34
All Time: 3,385
