Garmin Dezl 760LMT Screen Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
86
All Time:
3,192
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to properly and safely remove the Garmin Dezl 760LMT's screen from the motherboard and its casing.
Tools
    1. Garmin Dezl 760LMT Screen Replacement, Back Panel: step 1, image 1 of 2 Garmin Dezl 760LMT Screen Replacement, Back Panel: step 1, image 2 of 2
      • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
      Ask FixBot
    2. Garmin Dezl 760LMT Screen Replacement: step 2, image 1 of 3 Garmin Dezl 760LMT Screen Replacement: step 2, image 2 of 3 Garmin Dezl 760LMT Screen Replacement: step 2, image 3 of 3
      • Using a metal spudger, pry the device apart.
      • To recombine them, line up the two halves of the device and press them together.
      Ask FixBot
    3. Garmin Dezl 760LMT Screen Replacement: step 3, image 1 of 1
      • Turn the device over, laying it on its back with the screen facing upwards.
      • Lift the front panel away from the silver part of the back panel.
      • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
      Ask FixBot
    1. Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: step 4, image 1 of 2 Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: step 4, image 2 of 2
      • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
      Ask FixBot
    2. Garmin Dezl 760LMT Screen Replacement: step 5, image 1 of 2 Garmin Dezl 760LMT Screen Replacement: step 5, image 2 of 2
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Find and lift the small grey hinge at the end of the ribbon cable.
      • When handling the motherboard, make sure to wear an anti-static wrist strap.
      Ask FixBot
    1. Garmin Dezl 760LMT Screen Replacement, Screen: step 6, image 1 of 2 Garmin Dezl 760LMT Screen Replacement, Screen: step 6, image 2 of 2
      • Using a Torx T5 screwdriver, unscrew the four 7mm screws from the back plate of the screen.
      Ask FixBot
    2. Garmin Dezl 760LMT Screen Replacement: step 7, image 1 of 3 Garmin Dezl 760LMT Screen Replacement: step 7, image 2 of 3 Garmin Dezl 760LMT Screen Replacement: step 7, image 3 of 3
      • Turn the screen over so that it is facing upwards.
      • Remove the front plate of the screen.
      • Lift the screen from its back casing.
      Ask FixBot
Ryan Williams
763 Reputation
6 Guides authored
USF Tampa, Team 4-2, Passmore Fall 2016 Member of USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
4 Members
72 Guides authored
2 Guide Comments
where can one by the replacement screen
tempestrogue - Reply Share
Ebay sells these screens replacement - search online for “ZD070NA-03K “ or on google, even amazon sometimes has them. Its a hard to find screen so you will probably only get it from hong kong or china.
neilneves - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 86
All Time: 3,192
