Garmin Dash Cam 35 Screen Replacement
    1. Garmin Dash Cam 35 Screen Replacement, Case: step 1, image 1 of 1
      • Remove the two 1.7 mm screws holding the case in using a T6 Torx screwdriver.
      Ask FixBot
    2. Garmin Dash Cam 35 Screen Replacement: step 2, image 1 of 1
      • Use opening picks and the opening tool to pry the two pieces of the case apart.
      • Be careful when prying and try not to break anything.
      Ask FixBot
    3. Garmin Dash Cam 35 Screen Replacement: step 3, image 1 of 1
      • Carefully pinch the power cable, and slowly remove it from the motherboard slot.
      Ask FixBot
    4. Garmin Dash Cam 35 Screen Replacement: step 4, image 1 of 1
      • Carefully lift the lock on the motherboard for the ribbon cable. Unslot the ribbon after the lock is undone.
      • Remove the case.
      Ask FixBot
    1. Garmin Dash Cam 35 Screen Replacement, Screen: step 5, image 1 of 1
      • Remove the two 1.4 mm screws from the battery bracket using a Torx T5 screwdriver.
      • Lift the battery from the screen.
      Ask FixBot
    2. Garmin Dash Cam 35 Screen Replacement: step 6, image 1 of 1
      • Carefully use the ribbon cable to lift the screen from the case.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 137
