Garmin Dash Cam 35 Lens Replacement
    1. Garmin Dash Cam 35 Lens Replacement, Case: step 1, image 1 of 1
      • Remove the two 1.7 mm screws holding the case in using a T6 Torx screwdriver.
      Ask FixBot
    2. Garmin Dash Cam 35 Lens Replacement: step 2, image 1 of 1
      • Use opening picks and the opening tool to pry the two pieces of the case apart.
      • Be careful when prying and try not to break anything.
      Ask FixBot
    3. Garmin Dash Cam 35 Lens Replacement: step 3, image 1 of 1
      • Carefully pinch the power cable, and slowly remove it from the motherboard slot.
      Ask FixBot
    4. Garmin Dash Cam 35 Lens Replacement: step 4, image 1 of 1
      • Carefully lift the lock on the motherboard for the ribbon cable. Unslot the ribbon after the lock is undone.
      • Remove the case.
      Ask FixBot
    1. Garmin Dash Cam 35 Lens Replacement, Motherboard: step 5, image 1 of 1
      • Remove the six 1.4 mm screws using the Torx T5 screwdriver.
      Ask FixBot
    2. Garmin Dash Cam 35 Lens Replacement: step 6, image 1 of 2 Garmin Dash Cam 35 Lens Replacement: step 6, image 2 of 2
      • Lift the motherboard on the side opposite of the latch.
      • Remove the motherboard.
      Ask FixBot
    1. Garmin Dash Cam 35 Lens Replacement, Lens: step 7, image 1 of 1
      • Remove the lens from the case.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 19
All Time: 143
